OK I will try to answer as many of your questions as I can...
1. I just started, but my question is how many gallons does your pool hold, I seriously doubt you need that much bleach, if you are not having a problem, and just want to maintain your chlorine level, 1-2 gallons per week would be plenty.
2. If your CYA is extremely high, I would do a partial drain and refill to lower the level.
3.see above
4. I get mine at WalMart, I get the Great Value Ultra bleach, you can get 3/4 gallon for $1.28 or a 1.25 gallon for $2.28(means less bottles)
5. The bleach calc needs to be downloaded, I will find it and post it for you.
6. If you want to switch over this year, there is no reason why you can't, just stop using the pucks, and start using the bleach... that's what I did..
7. it won't put the pool out of commission or at least it didn't mine, it actually put mine into commision( I was dealing with an algae bloom and it took care of it, quick!) Just maintain your chlorine level between 3-6 ppm.
8. I honestly don't know the answer to this question, I have no idea!
9. You can buy it at the pool store, it's also known as stabilizer, it keeps the chlorine from burning off immediately, you need it in your water just not alot of it!
10. The only way to bring CYA is to do a partial drain and refill... sorry!!
I hope this helps just a little, keep reading here, read all the stickies and ask all the questions you have, none is too stupid. When I found this place, I was dealing with a huge algea problem, the BBB method cleared it right up and I have used it religously since. Make sure you get a good test kit, one that measures TC, FC, PH, ALK, CYA and CA... the readings will come in handy here. Welcome to the forum, do your homework and read all the posts, it will take you some time but you will be happy you did it, so will your pocketbook!!
Good Luck to you and be sure to stick around!!
