under_h2o
Pool Newbie here...
Had my pool startup last week with my PB. He shocked the pool, left some chlorine sticks, and test strips. I've ordered Ben's kit (not sure how long it will take to come).
Here are my pool specs:
Gunite/Pebbletec
40,000 gals; 3.5' to 8.5' depth
DE Filter
SWG (not turned on yet, PB will be back in 30 days to start it up)
Fill water was trucked in but has been supplemented with well water. I also have an auto-fill from well so I will probably need to watch the minerals.
So, until he comes back to turn on SWG, I'm on my own. Since I don't like/trust the test strips, I went to the local pool store for measurements.
TC: 0
FC: 0
pH: 7.4
Alk: 115
TDS: 350
CYA: 0
Water is clear and about 84 degrees..
Obviously the pool store is recommending shocking (Burn Out Extreme) then using Muriatic Acid to control the pH in case it rises. Are there other options like BBB until I'm ready for SWG?
Thanks in advance.
Bob
