Closed Thread
Thread: Pool Reno Lesson
    simsjim is offline Registered+ Thread Analyst simsjim 0
    Jul 2006
    Default Pool Reno Lesson
    I had some pool renovation work done on an old Sylvan Vacationer VL IG pool. - yea....Sylvan used to be in the vinyl business AND used to be independant of AnthonySylvan.
    I contacted them first, and they said they didnt do vinyl work any more. So after not getting any replies from a number of Independant contractors, I found a company that was eager to do the job.
    Well. if you want details I can email them to you, but just let me say, if you live in SE PA, DO NOT, DO NOT, DO NOT use FORCHETTI POOLS and SPAS . They are slick and trade under several names so be careful.
    That is my Construction and Repair Lesson Learned.....
    Default Re: Pool Reno Lesson
    Please do not post the same thread in multiple areas. We will simply delete the duplicates. I am going to delete your other copy of this right now.
Closed Thread
  1. Ok, my lesson learned the hard way.......
    By aylad in forum In-Ground Pool Construction and Repair
    Last Post: 05-21-2010, 03:57 PM
  2. Learned My Lesson
    By karrde97 in forum Dealing with Algae & Slime
    Last Post: 06-06-2007, 09:07 PM
  3. I need a pump lesson please
    By gordonhyde in forum In-Ground Pool Construction and Repair
    Last Post: 09-13-2006, 03:42 PM
  4. Adding CYA (Stabilizer) My Way - Lesson Learned
    By PatL34 in forum Pool Equipment & Operations
    Last Post: 06-03-2006, 07:23 PM
  5. DE Filters - Lesson Learned
    By rhosk in forum Pool Equipment & Operations
    Last Post: 05-10-2006, 04:59 PM
