Results 11 to 14 of 14
Thread: Test results
    Default Re: Test results
    Kath,
    We can back up our advice with facts, figures and empirical evidence of it working in thousands of pools.
    The pool stores are merely parrots for the pool chem companies who lose INCREDIBLE amounts of money from our advice.
    Here's the first thing to know about chlorine: ALL chlorine is exactly the same in the water.
    The various stuff they sell may or may not add unwanted chemicals. Bleach does not.
    Many pool stores sell "Liquid Chlorine 6%". This is IDENTICAL to generic Ultra Bleach. Identical. Only the package and label are different. Both are 6% Sodium Hypochlorite, 94% salt water.
    Read our stickied posts. Go to our sister site, PoolSolutions.com and read the tips. Follow our advice and your pool will be clean, you will have minimum of work, and you will save money.
    Hey! That sounds like all the snake oil salesmen! But the difference is that WE can back it up!
    Carl,
    I would gladly buy a huge bottle of the snake oil this forum is selling because it works!
    kathgilliam is offline ** No working email address ** kathgilliam 0
    Jersey Village, Texas
    Pat, I have read and reread your post. It seems with each day's experience, more and more of your post sinks in and the light dawns!
    I am convinced. I really want to be self-sufficient in caring for our pool. It may take quite a while to get me to that point, but that is my goal. I especially like the idea that I don't have to rely on the pool store for supplies or advice!!!!!!!
    K
    Saint Cloud, FL
    Glad you are seeing the light. Took me close to 8 years to get there. It's like trying on a dress or suit, and adjusting it until it feels comfortable.
    The only thing I do basically is add muriatic acid to keep the pH from 7.2 - 7.6
    and add a small amount of CYA after a backwash.
    Pat
  1. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  2. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  3. First test results
    By poolbee in forum DPD-FAS based testing
    Last Post: 06-15-2006, 11:27 PM
  4. First Test Results
    By Cutter in forum DPD-FAS based testing
    Last Post: 06-14-2006, 08:30 PM
  5. first test results
    By jazzbone in forum DPD-FAS based testing
    Last Post: 05-26-2006, 04:19 PM
