Results 1 to 10 of 10
Thread: Confused about CYA
    karrde97 is offline Registered+ Thread Analyst karrde97 0
    Peoria, IL
    Default Re: Confused about CYA
    I had the same confusion. My pool is in sunlight all day and I'm putting in 2-3 Quarts a night(On sunny days. Nothing on cloudy/rainy days). My CYA=40. Now it makes sense.
    A question I have is that the Best Guess Chart is based on FC. Does this mean I have to test my FC every day? I don't have enough powder(PS234) to do this all summer. I will have to buy more. I've been using the PS200 to check for CL & pH daily.
    21' AG 48" AquaLeader
    Central Illinois
    Indiana.
    Quote Originally Posted by karrde97
    It is intended that you do the daily check with the PS200. I only use the powder on Saturdays and if I have reason to suspect a problem.
    It's a good idea to check it daily until you get a feel for your pool--I can pretty much predict what mine's going to be from day to day based on my average daily chlorine loss.
    Peoria, IL
    The trend I'm starting to notice is that on sunny days I need to add 2-3 quarts. Rainy/cloudy days 0-1quart.
    Another question...Has somebody done a cost comparison of bleach versus chlorine? I'm curious since I'm putting so much bleach in per week.
    Central Illinois
    Indiana.
    Bleach IS chlorine, specifically sodium hypochlorite. Cost isn't the issue. Bleach, either as laundry bleach or the stuff you buy at the poolstore in higher concentration is the only thing that doesn't add something that will cause you trouble a few seasons down the road. Trichlor and dichlor add CYA. Cal-hypo adds calcium.
