Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 39
Thread: Stains returning
    .Joppa, Maryland
    Unhappy Stains returning
    After I did the ascorbic acid and the seqestering agent my pool looked great. I slowly raised the chlorine level with bleach and a couple of pucks in the feeder. My PH didn't drop much, so I added a little Borax. Now about 2 weeks later I see the stains returning. I backwashed the filter after the treatment. I added to my last post but got no response. All my readings are there. I just added more sequestering agent in the hopes it will clear up without another dose of ascorbic acid. I can't figure out what is going on. I haven't added well water, and my well is not supposed to have any iron anyway.
    HELP !
    Marty
    Default Re: Stains returning
    You either did not have enough sequestering agent in the water or you brought your chlorine levels up too quickly. Or possibly you brought you pH up too high with the borax. Post your numbers, it would help.
    .Joppa, Maryland
    Thanks Waterbear,
    I had put my readings in the earlier post I had edited. I added another bottle of sequestering agent last night (supposed to treat 20k gallons, I have 18k) I do think it looks a little whiter this morning. Here are my readings, the only change seems to be the CYA. FC=1.5; CC=0.5; TC=1.5; pH=7.4; ALK=70; CAL=30; CYA=100; TEMP=85. Will I need to add sequesterant on a regular basis to prevent staining?
    Again thanks for your help.
    Marty
    Quote Originally Posted by MartyW
    Thanks Waterbear,
    Marty
    Yes, keep adding the recommended maintenance dose and you need to keep an eye on your pH...don't let it get above 7.6 or staining could occur again.
    .Joppa, Maryland
    So if I understand this, the metal is in the water and it can't be removed? I will always have to use a sequesterant as routine maintenance? Is there other sources to purchase it in larger quantities?
    Thanks for you help
    Marty
    pretty much, unless you drain and refill with water that has no metal or the metal comes out of the water as stain.
    Not that I know of but the maintenance dose is only a couple of oz. ususally every week or two....sometimes you can get by putting it in once a month.
    Thanks for you help
    Marty
    hope this helps.
    .Joppa, Maryland
    Thanks again, I appreciate all your help.
    Marty
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    I am going to be using Metal Magic by ProTeam this week and it (in theory) will make the iron in the water "crystallize" so that it can be filtered and vaccuumed out.
    You aren't Marty Weston by any chance are you?
    .Joppa, Maryland
    No, the last name is Wagner. Let me know how the Metal Magic works. I suspect my metal is probably copper from my heater, although I really try to keep my pH high enough to keep it from leaching the copper out.
    Thanks Marty
    Jul 2006
    Upstate, SC
    I will post after I use the metal magic.. I think it's scheduled for delivery tomorrow. Marie (mbar) is also trying it out, she is actually who gave me the idea to try it.
    I would think your heater is where the metals (copper) are coming from. I don't have a heater so hopefully once I deal with the metals they will be out, until I have to add water or something.
  1. Metal Stains Slowly Returning
    By fedman in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-21-2012, 01:26 PM
  2. DE returning to pool - any suggestions?
    By atterbud in forum In-Ground Pool Construction and Repair
    Last Post: 06-02-2010, 09:26 PM
  3. Iron keeps returning
    By poolbuoy in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-18-2007, 10:35 PM
  4. sand returning in pool
    By cmtwhite in forum Pool Equipment & Operations
    Last Post: 06-06-2006, 04:44 PM
