Results 1 to 10 of 39
Thread: Stains returning
    .Joppa, Maryland
    Default Re: Stains returning
    Thanks again, I appreciate all your help.
    Marty
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    I am going to be using Metal Magic by ProTeam this week and it (in theory) will make the iron in the water "crystallize" so that it can be filtered and vaccuumed out.
    You aren't Marty Weston by any chance are you?
    .Joppa, Maryland
    No, the last name is Wagner. Let me know how the Metal Magic works. I suspect my metal is probably copper from my heater, although I really try to keep my pH high enough to keep it from leaching the copper out.
    Thanks Marty
    Jul 2006
    Upstate, SC
    I will post after I use the metal magic.. I think it's scheduled for delivery tomorrow. Marie (mbar) is also trying it out, she is actually who gave me the idea to try it.
    I would think your heater is where the metals (copper) are coming from. I don't have a heater so hopefully once I deal with the metals they will be out, until I have to add water or something.
    mbar's Avatar
    Ashland, PA
    Marty, If you keep your alkalinity in range - 80 - 120, and your calcium in range - with fiberglass I keep mine at 150 - 200, you can keep your ph as low as 7.0, and it won't damage the heater. If you have a fiberglass pool that is having staining issues, then I would keep the ph at 7.2, and no higher than 7.4. Keeping sequestering agent in at all times.
    Gerri, Take your ph down to 7.2 - with the additional sequestering agent, the stains should lighten up till you use the metal magic. Let me know how it goes. I haven't used it yet. I just got home from vacation and am having company, so I won't get to it for a while.
    Northeast PA
    .Joppa, Maryland
    Question Re: Stains returning
    Everyone says to keep the pH low to prevent the stains from coming back. I thought too low of a pH (acidic) would cause the copper to be leached out of the heater and subsequently cause more stains. Do I have it backwards?
    Marty
    mbar's Avatar
    Ashland, PA
    Anything below 7 is acidic, anything above is ok. If you have good alkalinity, at least 80, and a ph of 7.2, you will not leach out any copper.
    Northeast PA
    .Joppa, Maryland
    Thanks, Marie,
    When I last tested my ALK was 70. I have a vinyl liner. What should I try to keep it? What do I use to raise it without screwing up anything else?
    Thanks, Marty
