Results 1 to 10 of 39
Thread: Stains returning
    mbar's Avatar
    Ashland, PA
    Default Re: Stains returning
    When you post numbers, we will be able to see what is going on with the pool. If you can scrub off the stains, then they probably aren't from metals.
    Northeast PA
    Jul 2006
    Long Island, NY
    Yes I need to post my numbers.
    I'm going to the pool store today so they can test for metals.
    I just wanted to know if the Metal Magic worked so if I do have metals I will pick up some at the store.
    PS. the stains on my walls will not come off
    mbar's Avatar
    Ashland, PA
    I would pick some up. I haven't tried it yet - I have some, but have not had any staining yet. I have read some posts on the board who have used it. It may not take the stains that have been there for a long time off - but once they are off with ascorbic acid, it is supposed to turn the metals into crystals so that they can be filtered out. YOur water may not test positive for metals if the metal has already precipitated out onto the surface of the pool. If you post your numbers, I will help you through the stain removal.
    Northeast PA
    Jul 2006
    Long Island, NY
    Smile Re: Stains returning
    Thank you
    I'll post numbers tonight
    Jul 2006
    Long Island, NY
    The pool store said I did not have any Copper or Iron in the water.
    I’m giving you the numbers from my new test kit not from the store.
    CA=32
    PH=7.8
    TA=130
    CH=90
    CYA= 85
    I did the Vitiam C test (it took it off) and was told at the pool store to use algaecide so I thought I was fighting algae so I was keeping my CA high and scrubbing the pool.
    They did not have any Metal Magic so they sold me United Chemical Pool Stain Treat to get the stains off.
    Thank you for your help.
    Jul 2006
    Long Island, NY
    one more thing it's a 25000 gal kidney shaped pool with a heater
    DE filter
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    I used metal magic - while it wasn't exactly magical about taking off some tough old iron stains it did further lighten them - nothing so far has completely removed them though so it worked as well as Ascorbic Acid and better than Oxalic. One thing I do notice though is that I had little granules on the bottom after a couple of days. They were rust colored.. so possibly, and just maybe it did cause the iron I have to drop out of the water. I'm still seeing a bit of it each day and I'm cleaning it out each day. It looks like rust colored sand. It did take me a week to get my water clear again after the metal magic treatment, so I didn't post before now about results because I really couldn't tell about the stains. They are still there a bit, but lighter than ever. I think 1 more AA treatment may do the trick.
    mbar's Avatar
    Ashland, PA
    Is CA chlorine? If so your chlorine is high along with high ph which will make any metal that was in the water fall out onto the surface of the pool. United chemical is an oxalic acid. It will bring down your ph, along with your chlorine. With such a high chlorine level it may take a lot of stain treat, because the chlorine will eat up the oxalic acid. Even though your water didn't test for metals, it was in there - it can come from many things, fertilizer is one. Is your pool a plaster or vinyl or fiberglass. If it is plaster a calcium of 90 is not enough, you need 200 - 400 in a plaster pool. If it is vinyl or fiberglass 90 is fine.
    I would suggest letting your chlorine fall to normal level before doing the stain treat (so that you will not need as much product) - which for a cya of 90 would be 10ppm. You can use some muriatic acid to get your ph down while waiting for the chlorine to drop - I would take it down to 7.2 - 7.4. Your alkalinity is a little high also, it should not be higer than 120. Then you can do the stain treat, which will bring down you ph and alkalinty. Post your numbers after the stain treat - let me know if all of the stains come off. Good luck.
    Northeast PA
