Re: Uneven water level
Crushings are made from stone, basically it is made form limestone, and it is a bit bigger than sand, and flat, like flakes. It compacts really well and will not wash like sand will because it is aggregate and has irregular edges that lock together better.
And as for how do you level a pool with 18000 gallons in it, you would need to drain the water out of it in order to do it, then you would need to lift the effected parts including the blocks and place the crushings under the blocks. So you would slide a block out, put the stone in there and put the block back in and then tap it down as good as you can to seat it. Personally I would also pull the liner back half way so you could get at both sides, but I would imagine that you could get away with not doing it, but keep in mind that as you remove the block you will also be undermining the pool as that sand will likely fall into the void where the block was. Then once you raise the most effected blocks, work your way back and fix the other ones if need be.
In a nutshell, what you are doing is doing it right the second time, which is a frustrating, time consuming and costly thing.
