Results 1 to 10 of 74
Thread: AG Pool Audio System.
    Grand Prairie, TX, USA.
    Default Re: AG Pool Audio System.
    We use the Logitech mm50 speaker system with an iPod. It contains a rechargable battery and can simultaneously recharge the iPod and the mm50 when plugged in. Sound quality is very good and the unit is very light so it's not a chore to set it outside during the day and bring it inside at night.
    http://www.logitech.com/index.cfm/pr...ONTENTID=10785
    --Rx
    15,000 gal IG plaster/gunite pool & spa w/gas heater, 60 ft2 DE filter
    It's not completely relevant to your problem, but here's how I did my outdoor speakers. I used conduit, glued up like pvc pipe, and the same method could be applied to remote speakers with in-ground conduit. These are Boston Acoustics Voyager 6 units. Couldn't get the 7s but the 6s are good enough for me and handle 125rms watts each, with surprisingly good sound.
    I use an ancient set of Dynaco components--200wpch amp, with pre-amp and tuner. Then I have an ancient but wonderful Nakamichi cassette deck that flips the tape! And I just added a cheapie $80 CD changer than can hold 5 CDs and play MP3 CDs.
    Love it.
    Heartland
    Quote Originally Posted by CarlD
    Is this the life, or What!
    To sooth my throat I have a glass of 15 year old aged Martinique rum that's smooth as fine cognac, but a lot more exotic!
    Does it get any better than this?
    So CarlD, now I know where you sit to truly relax. NICE. Your speaker mounting setup would work just great for my situation. I could mount them on our sofet and angle them toward the pool. Spaced maybe 10 foot between the two. All the wiring would be in the attic.
    Now going wireless really has my ears perked up. I could set some poles around our pool and mount the speakers to them. I think that might look good also. They would defiantly be closer to the pool than if they were mounted to the house.
    Now, I haven't shopped speakers at all yet. But, what are the distance limitations to wireless speakers?
    Thanks for the picture and post CarlD, it really has me thinking.
    Hey gang, why not go all out. Underwater speakers. Check them out.
    http://www.shadebuilder.com/underwater_speakers.html
    I would check them out myself if the price were under a hundred. But that's just me.
    Enjoy the tunes and the pools, Dennis
    sailork is offline Registered+ Thread Analyst sailork 0
    Houston (Clear Lake area), TX
    I've got the bigger Yamaha outdoor speakers on the yacht. One pair on the deck, one pair down below. I bought them because they didn't take much power to drive and put out better bass than the smaller speakers. The only caveat is that they have a little bass "hump" somewhere just below a bass voice. You have to eq it out or they sound a little boomy. The upside is that if you eq it out they sound very very good. We tend to range Stan Kenton, AC/DC, Willie/Waylon so it's a mighty mixed bag and the speakers really never disappoint. They easily drown out the diesel, wind, waves, and an occassional angry tugboat pilot honking at., could it be us?
    They'd make wonderful pool speakers and Fry's and Best Buy often have them on sale for $99/pair. Plus you can say "Someone from the yacht club recommended them to me, Pip Pip!"
    Link to said speakers at Amazon
    22,000 gal gunite pool, 1.5 hp pump, DE filter, and dreams of a SWG.
    Scottsdale, Arizona
    Malibu wire for low voltage outdoor lights works great for speaker wire ... I have 4 speakers in my yard using the malibu wire to power them. I use 2 recievers in the house so I have seperate volume control for inside / outside.
    Speakers are Bose 151 Enviromental (10 years outside in the sun, rain and sprinklers and they still sound great) out in the yard and klipsch for under teh patio.
    try the malibu wire, you don't even need conduit in the ground then.
    That sounds nearly ideal Phillbo. Have you had any trouble with corrosion in the connection or has it held up fine? I'm wondering if I'll need to solder on a terminal...
    jabbajean Guest
    We just got a water proof, wireless speaker from Brookstone. You plug the transmitter into your stereo and carry the speaker where ever you want it to go. You can also hook your ipod up to the speaker..I LOVE it and I don't worry about splashing or get stuck in the rain.
    Jay
