Thread: Which chlorine test kit for numbers over 5
    Dec 2005
    Honolulu, Hawaii.
    Default Which chlorine test kit for numbers over 5
    Which chlorine test Kit for numbers over 5 should I get and where can I get it? An example would be if one wants to know if one has 6ppm versus 7ppm, or 4ppm versus 5ppm.
    Are chlorine meters any good for this?
    Aloha,
    Paul
    Default
    The best kit you can buy is sold by Ben (the administrator of this site) at the following link. It is the kit that most of us use simply because it is the best thing you can buy. A little expensive, but well worth the money.
    http://www.poolsolutions.com/cart/ps234.php
    Watermom
    Default
    Of course, I'm a bit biased, but I think Ben's kit is the one everyone needs!
    Seriously, the dpd/fas kit depends on number of drops required to create a color change, and will accurately measure chlorine levels up to 50 ppm.
    Default
    Quote Originally Posted by Watermom
    Watermom
    Guess great minds think alike, eh?? LOL
    Default
    Ben's kit is the BEST value for the money but there are other FAS-DPD test kits available from companies like Taylor and LaMotte. I did a comparison of Ben's kit with the salt option to the 3 Taylor kit's you would need to get the same tests and reagents and Ben's kit was by far the winner in initial price and number of tests you can do before needing a refill!
    Dec 2005
    Honolulu, Hawaii.
    Default Thank you all for the replies and how does it work
    Thank you all for the replies and how does it work.
    For example how would one arrive at a reading of 4ppm or 6ppm using Ben's test.
    Aloha,
    Paul
    Honolulu: 78F, trade wind at 16 mph to 25 mph, mostly clear skies. Oh my goodness I see a cloud approaching I better leave and get into my tanning machine.
    Default
    Quote Originally Posted by smallpooldad
    Aloha,
    Paul
    The FAS-DPD chlorine test is a titration test similar to the titration tests for Alkalinity and Calcium Hardness. By counting the drops necessary for the color change to occur you then can calculate the ppm of FC and also TC and then therefore get your CC by the formula TC-FC=CC./
  1. Hello new friends and first test numbers.
    By shastablast in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-24-2013, 10:51 PM
  2. numbers from test
    By mrs.rainbow in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2011, 11:11 PM
  3. Test Numbers/Chemicals
    By AGP18by33 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-20-2006, 03:11 PM
  4. Got the new test kit. Here are the numbers. Tell me what to do.
    By rfreeman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-25-2006, 05:18 PM
  5. Test numbers are scary!
    By marciastz in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-14-2006, 12:32 AM
