Re: Waterline Tile Replacement
Waste, thanks and it is phase 1. Hopefully we will be able to find a contractor that is local and reputable.
Another question. What is used to lay the coping stones on over the skimmer outlet? Meaning the area in front of the skimmer where the pool water enters the skimmer mouth. My coping stones are only 3" X 8" so obviously they wont span the opening. I was thinking I could fabricate a concrete form and pour the concrete and then use over the opening, but I would prefer to be able to use my coping stones around the entire perimeter of the pool. Perhaps a sheet of stainless steel should be place over the top and then I could tile the bottom so it would not be seen?
Also, not sure if you saw my post regarding my tile being 1-2 inches above the beam...would sure like to hear your recommendation for that. I am working in the backyard and taking breaks only to check this website! Looks like I have become dependent on technology/internet.
Dave
