Pool Rover Plus for me...
I have the same leaf, pine needle and bug problem...
I had the Aquabot and I DOWNGRADED to the pool rover plus. The Aquabot got stuck on my main drain, stairs, ladder, return fittings... It was far from drop it in and forget it. After 2 months of headaches, I sold the unit... for some pools, they're great but not for mine. I'm sure it'd have eventually torn the liner on the stairs where it used to get stuck.
The Pool Rover Plus is a much simpler design (no fancy electronics that outsmart itself) and basically gets the pool every bit as clean as the Aquabot except thae waterline, stairs and corners which is no big deal. It also got my pool clean in 2~3 hours vs 8 (for the aquabot).
Different folks have varying degrees of success with different types of cleaners. Almost everyone who has a Pool Rover Plus seems to like their cleaner (I remember one person last year reported poor coverage with it). It's a shame you can't test drive a cleaner... once a pool cleaner is put in your pool, you can't return it. For me the Pool Rover Plus works great.
That said... I jst purchased a much bigger DE filter for my pool and went from 54GPM designed flow rate to 96 GPM. I also upgraded the pump from a 3/4HP to a 1HP. So I purchased a thepoolcleaner pressure side cleaner which doesn't require a booster pump.
Why? Here's downside to the pool rover plus (and the rest of the robotics)...
While I really like the Pool Rover Plus, dragging it out of the garage and putting it in the pool, dragging it back out and storing it is somewhat of a pain. My wife who is very petite is not strong enough to lift it out of the pool once it's finished its cleaning cycle.
Since thepoolcleaner is designed to "live" in the pool 24x7, it's cleaning whenever the pump is on. The pool will be clean pretty much all the time and ready to go.
If thepoolcleaner and the bigger DE filter combination is enough to keep the water polished, I'll sell my Pool Rover Plus. If not... I'll just pull it out once in a while for deep cleanings only.
26,000 Vynil Liner L Inground
Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
Poolvergnuegen thepoolcleaner Pressure Side Cleaner
Loop-Loc Mesh cover
