Closed Thread
Thread: too much bleach???
    rnjng Guest
    Default too much bleach???
    I noticed that the liner in our pool is almost white on 1/2 of the floor. would this be from to much bleach??? liner has a pattern and is more blue spots. Oh while I'm posting, the bottom of the pool is very hard, is this normal?24' round ag 13570 gals
    Default Re: too much bleach???
    Is the liner white or is it debris on the bottom? Hard floor is good, very good. It means the sand is properly packed down.
    duraleigh Guest
    How much bleach did you put in?
    rnjng Guest
    to answer carls ques. no the liner has a pattern on it. and the one side opposite the return flow is pretty faded.
    Duraleigh, I use bleachcalc to adjust clorine levels, but I thought I had alge, maybe I did, I don't know, but I prepared the fight the alge and stocked up on bleach. I put in the required amount for shock level, and it held overnight on the first dose. That was the only time I used an eccess amount of bleach.
    duraleigh Guest
    If you put in the bleach using bleachcalc and Ben's table, the bleach application was very safe.
Closed Thread
