Thread: Northstar strainer cover
    Default Northstar strainer cover
    I can't get my Hayward Northstar strainer cover off. Is there some trick to it?
    Davenj is offline Lifetime Member Thread Analyst Davenj 0
    Jersey Shore
    Default
    Mine is difficult (stuck) at times also. I keep the gasket greased and that seems to help a little. It is alot harder to remove than my old pump was. Not much help!
    Sacramento, CA, USA.
    Default
    Try loosening the cover with the pump running. The suction of the pump should pull the lid down just enough to allow the ring to move.
    Default
    Thanks poolman1. I'll give it a try.
