Thread: If I were to build my own Pool, I would use the following equipment???
    Jul 2006
    Pearland, TX (Houston suburb)
    Default If I were to build my own Pool, I would use the following equipment???
    OK, I am new to the site and in the market for a new pool. I have 5 bids out right now. I have seen equipment from Jandy, Hayward, Pentair, etc. If anyone of you (existing pool owners) had your choice now, what equipment would you select? (my pool = In ground Gunite - 18x36 20,000 gal. Salt Water System)
    Pumps -
    Filters -
    Valves -
    Controllers -
    Lights (mulit-color) -
    Also, with the salt systems now being designed, does anyone have a preference over the newer aggregate pool coatings over the old reliable plaster?
    I welcome any and all opinions.
    the woodlands, texas.
    Default Re: If I were to build my own Pool, I would use the following equipment???
    Equipment from any of the Fab 4 (Jandy,Pentair,StaRite,Hayward) is all well engineered and constructed. If you buy a full equipment set (any 3 of this 4, heater, filter, motor, controller) you'll be rewarded with an extended warranty.
    My preference is:
    1st Jandy
    PHPU 1 hp no spa, 2hp with spa, DEL 60, Neverlube, PDA radio remote, and JPL colored lights
    2nd Pentair
    Whisperflow or Challenger (same hp's) FNS 60, Neverlube, Intellitouch
    3rd- StaRite
    4th- Hayward
    You can't go wrong with any of the products from these Mfg's
    See Ya,
    Kelly
