Re: Pool not Priming???
I was having the same problem yesterday.
After removing the basket in the pump and emptying it, i stuck my finger into the hole at the bottom of the pump's water chamber (power was off, very off). Sorry for the technical vocab. Turns out that the impeller was jammed with leaves and pine needles. After cleaning it up, the pump works like a charm.
Thanks... I will check on that part of the pump (with the power off).
