Results 1 to 10 of 15
Thread: Pressure side vs Suction...?? :confused:
    sailork is offline Registered+ Thread Analyst sailork 0
    Houston (Clear Lake area), TX
    Default Re: Pressure side vs Suction...?? :confused:
    I vote Suction Side.
    I've got a Baracuda G3. I have no idea how it compares to the other suckers. The best thing about suction side cleaners is the way that they "suck up" the debris cloud that they generate. The polaris etc tend to just shoot the fine stuff up into the water and hope the skimmer catches it. People complain that it tends to fill the filter quicker that way. I say good. It's filling the filter with things I don't want in my pool. That's what the filter is for. DE is cheap. Most importantly though, the suction side cleaners are far and away the lowest TCO of any automatic cleaner that keeps me from needing to vacuum my pool.
    22,000 gal gunite pool, 1.5 hp pump, DE filter, and dreams of a SWG.
    Jul 2006
    Interesting. On your Legend II, do you have to close your other returns and how does that affect skimming if you just want to circulate? Do you never run the pump without the cleaner, adjust the the returns each time, or just let it run without good directional flow? I've got 3 returns and my pool is 43 feet long at its wide point, and need all 3 returns for skimming. Also, how much is extra hose? One thing that bugs me is having to buy extra hoses before I can even set up. Do you think it coudl fit into one of those rubbermaid pool deck boxes when not in use? Lastly, how does it do an dirt and sand, do you need to buy a seperate bag to clean that effectively?
    Thanks.
    Jul 2006
    I switched a couple months ago from a Polaris pressure side cleaner (w/ a booster) to a suction side clear (www.thepoolcleaner.com) on a dedicated suction line.
    At the same time I switched from a DE filter to a sand filter filled w/ Zeobrite.
    All these changes where driven by a change to a super efficient pump (Ikeric). Right now I've just been a running in really low speed mode.
    After I killed the residue from some algae in the pool that was present during the switchover the pool looks as well if not better than it did before. There is a leaf canister inline with cleaner so some of bigger debris doesn't make it to the filter.
    The pool is now configured with a "roving main drain". Suction happens on the skimmer and the cleaner. The old main drain is disabled.
    The interesting thing I noticed is the steps that the cleaners can't reach are staying cleaner. My guess is with the old pressure side cleaner debris would get thrown up into the water and it would settle down onto the steps. With the suction side cleaner there is less of that.
    I really wanted to have the most energy efficient cleaner that I could have and the suction side cleaner w/o any booster pumps fit the bill.
    The cleaner stays in the pool most of the time. If we are having a party/company I pull it out. The hose is easily broken apart into sections so I can easily lay it out straight.
    I considered robotic cleaners. One of the apparent drawbacks is I just can't leave them in the pool. I would need to cart them out and then cart them back in. I have visions some day of "Roomba" like cleaner than lives in a "garage" and comes out to clean and then stores itself when it is done.
    arnold
    Quote Originally Posted by jimwnola
    Thanks.
    Yes, I close the returns in the deep and shallow end when vauming. The main drain and skimmer are always open so the skimmer is still working. When done vauming, I open the returns for the deep and shallow ends.
    Not sure how much hose comes with the cleaner. My pool is 38 feet long and I had to cut some hose off.
    One of the Rubbermaid pool deck boxes should work fine.
    The cleaner comes with a fine filter bag that does a good job with dirt and sand. Just let the bag dry out before cleaning and then everything comes out easily.
