Hello-
We put in an inground, blown concrete pool, PebbleTec finish, and a salt system, last September. Ever since, the water has seemed very salty even tho the testing and system electronics tell us otherwise.
As Tenax asked, what is the salt level in your water (in parts per million or ppm)?
Are salt sytem pools supposed to have salty water?? I thought it was only supposed to create Chlorine in a less caustic manor since my whole family has sensitive skin.
Most people can't tast salt in the 3000-3500 ppm range that most SWG manufacturers recommend. Some systems (Watermaid, I think) operate in the vicinity of 6000 ppm and you can probably taste the salt at that level.
Our pool company, as part or our sales contract, comes out every 3 months to check everything and will clean our DE filter at the 1st year end...then it is up to us...We do all the pool maintenance ourselves.
With the help of this forum, that should be easy for you. Read the sticky threads at the top of the "Using Chlorine and Chlorinating Chemicals" forum and the "Testing and Adjusting Pool Water Chemistry" forum to get started on understading your pool water and how to maintain it.
Our service tech (from our pool builer) was out on Monday to replace the board on our salt system that went out, and for the first time, told us to add 10 lbs stabilizer...this was the 1st I had heard about this chemical.
Stabilizer (aka conditioner) is the common name for Cyanuric Acid (abbreviated CYA). It keeps the active form of chlorine from being detroyed as quickly by sunlight. Most SWG manufacturers recommend a level of 60-80 ppm CYA; check your owner's manual to see what your manufacturer recommends. You can buy it at pool stores and at some of the big box stores such as Wal Mart and Home Depot.
What does it do for the pool and how do we know when to add it??
What it does is above. You know when to add it by testing your water for it. It's generally not a consumable like chlorine; once it's in your pool it's there to stay (with some exceptions).
We add Acid weekly and a Scale additive monthly....
How do you know how much acid to add? Are you testing your own water? With what?
What are we doing wrong with the salinity...if anything???
Let us know what the salinity is and someone here will be able to help you.
Thanks for your help in advance!
