Thread: Waterbear - question - how to calibrate SWG?
    west1745 is offline Registered+ Thread Analyst west1745 0
    Dec 2005
    Default Waterbear - question - how to calibrate SWG?
    Hi Waterbear,
    the other day you mentioned that you have to calibrate your SWG meter with the drop test.
    How do you calibrate it? I think I have the same one as you - the Goldline.
    THANKS!
    Default Re: Waterbear - question - how to calibrate SWG?
    IF I am not mistakes the newest software revision of the goldline units allow for calibration of the reading. The older ones do not. I do not know the procedure.
    Dec 2005
    Quote Originally Posted by waterbear
    Okay - I guess I must have the older one because I do not see a way to do that and do not see it in the manual.
    So far it seems that it is between 300 and 400 off. That is not too bad. I have the Taylor drop test so I keep an eye on it regularly.
    Thanks for all of your help - always enjoy reading your posts.
  1. How to calibrate flow sensor?
    By Ronald in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-01-2011, 03:25 PM
  2. Thanks Waterbear for the info one more question
    By jenpen400 in forum Dealing with Algae & Slime
    Last Post: 07-16-2007, 10:09 PM
  3. How to calibrate Autopilot
    By Tominthedesert in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-12-2006, 11:46 PM
