Thread: NEW POOL WATER ....Quick
    Jul 2006
    Default NEW POOL WATER ....Quick
    Since I wont have my test kit for about 10 days or so I need a little advice
    Free chlorine .42 ppm
    Total chlorine .42 ppm
    Current PH 7.7
    Calcium Hardness 230ppm
    Alkalinity 120 ppm
    Cyanuric Acid 5 ppm
    Copper 0
    Iron 0
    Total Dissolved Solids 220 ppm
    CHris
    Default Re: NEW POOL WATER ....Quick
    What kind of pool do you have? Regardless, I'd say raise your Cl to 3, add some CYA (target around 20 ppm), and leave the rest alone. If it's plaster/concrete, or have a heater/SWG or other special equipment, that might change things.
  1. New to Pool Care, Need Advice, and a quick hello!
    By PoolN00b in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-27-2012, 06:55 PM
  2. New pool owner--need some quick help to salvage last weeks of season
    By NJ Aqua in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2011, 10:14 PM
  3. Pool Filled! Quick question
    By dmarsh70 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-26-2010, 05:56 PM
  4. New Pool Owner With 2 Quick Questions
    By NullQwerty in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-23-2006, 11:49 PM
  5. Hot Weather Came quick! Green pool needs attention :)
    By scarywoody in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-23-2006, 12:39 AM
