Closed Thread
Thread: Floating liner? What to do/
    NY
    Default Floating liner? What to do/
    We had over 10 inches of rain on Friday and Sat. and my ground is saturated. In the pool today we noticed that the liner seems to be floating a little in the shallow end. Not a lot, but it seems sort of soft and squishy where the wall meets the floor. Is this a serious enough problem to call the pool tech or should I wait to see if it goes down-will it go back by itself?
    Thanks.
    Honesdale PA
    Default Re: Floating liner? What to do/
    Since nobody has responded yet I'll throw in my cents worth until you get a quarters worth of info. I'd use something like the vacuum brush to try and smooth it out and keep it from wrinkling as the ground water slowly subsides and it fills back out. No way of telling how long it will take but keep an eye on it and help it along as necessary.
Closed Thread
  1. New IG Pool Help -- Liner floating repeatedly
    By remmy in forum In-Ground Pool Construction and Repair
    Last Post: 06-28-2013, 09:36 AM
  2. liner detaching and bottom floating
    By chemstick in forum In-Ground Pool Construction and Repair
    Last Post: 06-14-2011, 04:09 PM
  3. IG Floating Vinyl Liner
    By Tillysaint in forum Pool Equipment & Operations
    Last Post: 09-09-2008, 04:28 PM
  4. Floating Pool Light
    By NullQwerty in forum Pool Equipment & Operations
    Last Post: 05-28-2007, 06:49 PM
  5. Floating Solar Disks
    By hooktee in forum Pool Equipment & Operations
    Last Post: 05-14-2007, 09:35 AM
