Re: TA Issues; First-Year Pool Owner
I use muriatic acid to keep my high PH and TA in check. You can also try to point your returns straight up and see if that helps get the PH up.
Also, noticed that your CCs were as high as the FC. If true, you need to shock your pool and get the CC down close to zero. This is probably the reason your water is cloudy. Go by Ben's table and bleachcalc for amounts. You might want to get a better test kit (DPD or FAS-DPD type) to double check your numbers.
