Re: What automatic cleaner for AG pool?
CarlD
Those two things and the Polaris should make you MUCH happier.
Lining the Polaris net worked like a dream! We did the dreaded algae-under-the-steps maintenance this weekend. I had put a sock in the skimmer basket to keep this nasty stuff out of the sand filter while vacuuming, and that worked very well. Then I put several layers of cheese cloth inside the Polaris net and put it to work on the fine stuff, and boy howdy! Great job! Not only did it weight the net down just enough to keep it level but it turned green with stuff you can't even see.
I sure do appreciate your help!
