Well that makes a little bit of a differenceWith a CYA of 20 your FC is just right at 4 ppm. Now the sand bit I don't know about, we have a CART filter.
CYA = 20?
Ok, shock to 10 or 12 and hold it there until algae is dead, then maintain between 3 and 6ppm.
You should raise CYA to 30 or 40--Use 1/3 to 1/2 of what you calculate you'll need to get it there.
Or you can use Tri-chlor pucks/sticks --they'll add it.
Sounds like you have mustard algae. Its brown and looks like sand. Sits on the bottom of the pool in spots about htes size of a quarter. Sound like your problem? I don't think its sand since you stated that it disappears when touched. Sand doesn't dissolve, so it wouldn't do that. This algae seems bloom right after a good rain. You need to shock like they say here and hold it there for a couple of days or even a week until the algae doesn't return anymore. Also need to vacuum that stuff to waste to get it out of your pool. To keep it from coming back in the future, I would shock every time after a good rainfall.
