Results 1 to 5 of 5
Thread: zeobest problem
    Default zeobest problem
    I have a zeobest filter that keeps putting fine particles of zeobest back in my pool. Its over one month old and I backwashed it when brand new for a good 5 munutes. Help. phil
    jenpen400 Guest
    Default Re: zeobest problem
    I used zeobest also and had no problems. Could be too much media. Could be the pump is too strong for the size of the filter. I think I might have little go in on my first start up but all been well since then. I'm happy with the zeobest product. Hopefullly someone who knows more can help'
    Good Luck
    jennifer
    Wink Re: zeobest problem
    thanks jenpen 400 im still working on it
    waterbear's Avatar
    St. Augustine, Fl
    It is possible that you have a damaged lateral in your filter.
    RavenNS is offline Established User Weir Watcher RavenNS Not to be trusted
    Jul 2006
    Nova Scotia CANADA
    I don't know if this helps, 'cause I'm a newbie, but when I had switch from sand to zeobrite during spring-opening, I kept getting particles in my pool as well.
    Would vacuum them up & then by next morning the pool bottom would look like a beach.
    Figuring that vacuuming wasn't working well, I converted my Pool Buster to hold a filter sock ( inside of the mesh bag that it comes with) & would remove the particles.( this helped a bit, but still had a lot of debris each day)
    Eventually the pool store that did the opening ( & replacement of filter contents) admitted that they may have messed up putting the filter back together; Aparently there is a "rod" in the filter that must be placed vertically. The rod was askew in my filter & this caused the zeobrite to be continuously dumped into the pool.
    So I guess what I'm saying is:
    check that the filter is completely assembled correctly
