Thread: zeobest problem
    Default Re: zeobest problem
    It is possible that you have a damaged lateral in your filter.
    Jul 2006
    Nova Scotia CANADA
    I don't know if this helps, 'cause I'm a newbie, but when I had switch from sand to zeobrite during spring-opening, I kept getting particles in my pool as well.
    Would vacuum them up & then by next morning the pool bottom would look like a beach.
    Figuring that vacuuming wasn't working well, I converted my Pool Buster to hold a filter sock ( inside of the mesh bag that it comes with) & would remove the particles.( this helped a bit, but still had a lot of debris each day)
    Eventually the pool store that did the opening ( & replacement of filter contents) admitted that they may have messed up putting the filter back together; Aparently there is a "rod" in the filter that must be placed vertically. The rod was askew in my filter & this caused the zeobrite to be continuously dumped into the pool.
    So I guess what I'm saying is:
    check that the filter is completely assembled correctly
  1. Another Problem!
    By Spike in forum In-Ground Pool Construction and Repair
    Last Post: 05-11-2012, 04:10 PM
  2. Zeobest Sand
    By Mike_S in forum Pool Equipment & Operations
    Last Post: 06-19-2011, 09:12 AM
  3. Algae problem or fliter problem ?
    By ROBIN13 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-14-2006, 03:29 PM
  4. Big problem! Need help!
    By kelleyb in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2006, 07:08 AM
  5. New Problem...
    By Dafreak in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-22-2006, 10:05 AM
