Results 1 to 10 of 22
Thread: Getting a new fiberglass pool
    mbar's Avatar
    Ashland, PA
    Default Re: Getting a new fiberglass pool
    Yes, I think it was the second payment when the pool went in- it was 7!/2 years ago, so I am not too sure. Half was put down before the work started, and the rest when the pool went in the ground. I still had to pay for the rest of the concrete, which was separate from the quoted price of the pool. The pool went in on the same day. As soon as it was in they measured it to make sure it was level, then back filled around it and started to fill it right away. It was lifted in with a crane! It looked like a big bathtub. I know that it was then filled and then the pump was started up. It was a while before they did the concrete. It is really hard to remember the exact sequence - but I know it was really fast.
    Northeast PA
    keithw is offline Registered+ Thread Analyst keithw 0
    I've got a CPC 12 x 24 that I installed myself. Upkeep on it is very easy. I did have to add vitamin C to kill some stains early on but it's been pretty stable since then. I can see hte advantages to a cantilevered edge. We tend to lose water when a quite a few people get active in the pool and an overhanging edge would eliminate that. Here's a link for my pool install,
    http://s36.photobucket.com/albums/e4...vab/?start=all
  1. Off Level Fiberglass Pool
    By Rudy2012 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-05-2012, 07:36 PM
  2. Fiberglass pool
    By Aboabdo in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-01-2011, 05:57 PM
  3. Concrete in new fiberglass pool
    By [email protected] in forum In-Ground Pool Construction and Repair
    Last Post: 09-03-2006, 02:20 AM
  4. Fiberglass Pool
    By DONNIE in forum Dealing with Alkalinity and Calcium
    Last Post: 07-12-2006, 01:02 AM
  5. Fiberglass pool question - can they pop out?
    By tybeeware in forum In-Ground Pool Construction and Repair
    Last Post: 06-05-2006, 01:32 PM
