Thread: Pool Newbie w/ questions galore!
    Default Re: Pool Newbie w/ questions galore!
    Good advice Virangos, I am here to add a little more. See this thread.
    http://www.poolforum.com/pf2/showthread.php?t=4411
    As for converting to overlap. I would definately do so. You will probably just need to buy coping strips when you buy the new liner. The coping goes over the liner and the metal rods would go over the coping. Most pools that come with a beaded liner have a metal retaining rod that goes over the bead receiver.
    You would simply replace the receiver with the coping.
    If that is not the case with your pool send a pic or two and I can help you convert it.
    Later, Dennis
    Jul 2006
    Thanks For All Your Help. Dennis- The Pics Were Very Useful. I Usually Have To Read Something And Then See How It's Done To Understand And The Pics Did Just The Trick! Thanks Again. Polly
