Results 1 to 5 of 5
Thread: Bens Bleach Calc???????????
    Carterville,IL
    Default Bens Bleach Calc???????????
    I Have Been Trying And Trying To Find This. I Click On The Link But It Downloads Nothing. I'm Using A Mac So Maybe That's It.
    Can You Help???? I Really Want To Try To Use It And I Won't Do Bleach Until I See It.
    Honesdale PA
    Default Re: Bens Bleach Calc???????????
    The bleach calc is not MAC compatable. Only Windows from what I know.
    MWSmith2's bleach calculator is a Windows only program -- no Linux, no MAC's, etc.
    Sorry!
    Ben
    But you can program the bleach forumla into any spreadsheet:
    FC = (1,000,000/PoolVol) * Concentration * BleachVol
    FC is Free Chlorine added in ppm
    1,000,000 is because we are computing Parts Per Milllion--ppm.
    PoolVol is the number of gallons or liters in your pool
    Concentration is the strength of your bleach as a decimal, not a percentage. So 5.25% is entered as .0525, and 12.5% is entered as .125
    BleachVol is how much you are adding, in gallons or liters--it just has to be the same units as PoolVol.
    So if you add 1 gallon of regular bleach to 10,000 gallons in a pool, the formula looks like:
    FC = (1,000,000 / 10,000) * .0525 * 1
    and therefore FC = 5.25ppm added.
    This gives us a REALLY easy rule of thumb: 1 gallon of bleach added to 10,000 gallons will ALWAYS give us its concentration as ppm added.
    So if you run the formula with 1 gallon of ultra, (6%), you'll get 6ppm, with 12.5%, you'll get 12.5ppm. And if you try it with a 3-quart bottle of Ultra, well you'll get 3/4 of 6ppm--4.5ppm. Very easy if you cannot get MWSmith2's calc because you have a Mac.
    It doesn't compute all the other stuff Michael computes, but it does do bleach.
    IL.
    Where is the good Mr. Smith these days?
