Results 1 to 10 of 13
Thread: Should I salt my pool?
    keithw is offline Registered+ Thread Analyst keithw 0
    Default Should I salt my pool?
    I have read a few links from people who have added salt to their chlorinated pools and say that they relly like the results. I was looking for input on doing this myself. I have a 6000 gal fiberglass pool. I'm using the BBB method (as of a week ago). All seems fine, the water is nice a clear.
    1. Can I added salt and continue on the BBB method? Do you eventually have to get a SWG?
    2. Do you have to keep replenishing the salt?
    3. What if you stop adding salt? Will it eventually go away?
    Anyone added salt to a chlorinated pool and regretted it?
    Thanks for any input!
    IL.
    Default Re: Should I salt my pool?
    Quote Originally Posted by keithw
    Yes. No.
    Only if it's lost by splashout or backwashing. Bleach adds a bit of salt as well.
    Yes, see #2.
    Not yet
    You're welcome
    Beatrice, NE.
    I have a 14' Intex pool that holds about 2,800 gallons.
    My nieghbor and I were discussing the whole salt in the pool thing and he has a water softener so he gave me a partial bag of salt he had - according to my bathroom scale it had 37 pounds in it. It was "solar salt" and the granules felt sharp so I disolved the salt a little at a time in a bucket with pool water and then poured it in. My family hasn't noticed the difference. There might be a slight taste if you get some pool water in your mouth, but that's about it. We really haven't noticed the softer feel, etc..
    It's cheap and easy to do so if you're curious go for it. I don't regret doing it, but I doubt I'll do it next year.
    /Steve
    Ft Lauderdale, Fl
    Do your kids wear goggles when they go underwater? The amount of salt you added should have gotten you to about 2500 ppm, which is higher than what most Non-SWG pool owners take their salt level to. The "noticable" feel may not be as noticable due to your water chemistry.
    What are your pH, Alkalinity, Hardness, Free Chlorine and Total Chlorine levels?
    If your pH, hardness, or combined chlorine levels are already on the high side, it may neutralize the soft water feel by being in an irritating condition to begin with.
    Sean Assam
    Marion, OH
    I found this forum earlier this year, switched to the BBB method, after having a pool for 10+ years. Our pool has never looked better! Then I added 80 lbs of solar salt to our 10,000 gal inground pool, and it's never felt better! Do it!
    I just did mine. It's killer!. Swam around for a long time to test the eye sting effect. There wasn't one..Very cool. I'm at 2500ish PPM and it seems fine. No noticable taste.
    Middle Missouri
    We added the solar salt to our pool and got it to about 3200 ppm. It feels great and my wife stopped complaining about her skin feeling dry after a swim. I don't regret this move at all!
    Jim
    16' x 32' / 15,400 gal / IG vinyl
    All testing done with
    PS234 test kit
    slhalufska is offline ** No working email address ** slhalufska 0
    port charlotte, fl, usa.
    i'm pretty new here.
    what is the BBB method? and what does the "G" in SWG mean? Also, does anyone know where I can get a replacement skimmer? Can't find a Hayward SP1086B1 anywhere. Wondering if it's discontinued. The guys who installed my 14x28' fiberglass pool glued the threaded fitting into the unit. We now have a leak and have to pull the whole unit out. (this is just the most recent of a long, long list of leaking problems with the installation. we haven't been able to pour the deck yet because of the problems and the darn thing was installed 12 wks ago!!!!) thanks for any help & info.
    sue
    The "G" in SWG stands for Generator. An SWG takes salt out thew pool and converts it over to chlorine. THe BBB method refers to maintaining you pool with Bleach, Borax and Baking Soda. These are technically the only three chemicals that you really should need to maintain a Chlorine pool. Unfortunatley I cannot help you with the skimmer but you would be smart to post that question as a new thread instead of burying it in here. Also, I would put it in the pool repair forum instead of this one.
    Keith
    court475 Guest
    How many ppm is a good amount for a non-SWG pool?
  1. Salt water system faulting high salt.
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2013, 10:43 AM
  2. Aqua Rite low salt reading when salt has been tested high
    By DirtRider67 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-19-2011, 05:58 PM
  3. Salt for non salt generator pool
    By graciec in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-04-2007, 01:26 PM
  4. Salt in a Non-Salt Water pool
    By wollypog6 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-31-2006, 10:01 AM
