Results 1 to 10 of 13
Thread: Should I salt my pool?
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Default Re: Should I salt my pool?
    Quote Originally Posted by court475
    How many ppm is a good amount for a non-SWG pool?
    It depends on the level of stabilizer (CYA) in your water. See this thread for a "guide".
    http://www.poolforum.com/pf2/showthread.php?t=365
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    IL.
    Court, did you mean ppm of salt?
    If so that's independent of CYA levels.
    I could tell a water quality difference at 1200 ppm. Anywhere from there up to 3000 ppm should do.
    Start at around 1000 and add more as you feel necessary after you've had a chance to swim around and judge it for yourself.
    Range, you're right...it slipped my mind that we were talking about salt! When I see ppm my mind automatically shifts into chlorine mode!
    Sherra
