Results 1 to 10 of 22
Thread: Anyone having trouble with Salt test?
    giroup01 is offline Registered+ Thread Analyst giroup01 0
    Canada
    Default Re: Anyone having trouble with Salt test?
    Also remember that the endpoint for the salt test, Taylor's anyways, is the first color change, not the second. It starts yellow, then turns milky, then turns sort of pink/red (bingo!), then turns brown. The first color change (pink) is the endpoint.
    Reseller of Taylor water-testing products for Canada
    Pool store says my salt is at 3000ppm. The pool was brand new in Aug '06, closed in Oct '06 and opened last week. Less than 3 months of usage and the SWG has already been replaced once before and now it's not working again.
    Makes you thing the problem is not with the SWG but maybe the plumbing or hook-up, right?
    The only other problem could be that the salt level really is too low and the tests have been inaccurate. Maybe I'll test it again somewhere else to rule that out as a possible scenario. Any other suggestions would be appreciated.
    Thanks.
    Quote Originally Posted by Jeffski View Post
    Thanks.
    I suspect that your SWG might not be hooked up properly or is malfunctioning. You can get pretty accurate salt readings from the Aquachek White salt test strips. I have checked them against chemical tests and 2 different meters (Goldline and LaMotte) numberous times and they have always been right on the money (well within 200 ppm, which is the accuracy of the Taylor test).
    I agree, but it is the second unit in three months so it is doubtful that the unit is malfunctioning. More likely it is hooked up wrong.
    It is plumbed in the line right after the heater with the flow arrow pointing away from the heater. Water comes into the drains/skimmer - through pump - through filter - through heater - through SWG - into pool, right?
    One other interesting yet probably irrelevant point... the return line that runs to the diving board/waterfall is plumbed between the heater and SWG so that water never goes through the SWG, just straight into the pool. That line is turned off 99% of the time and the SWG readouts appear the same whether that line is on or off.
    It is possible to have 2 defective units or an improperly installed unit. Also, the pool store might have a miscalibrated meter. I would suggest getting the Aquachek White salt test strips. They are pretty accurate. If your salt is more than about 400 ppm from what the strips say then I would suspect a problem with your unit (many SWGs will show a salt level that is as much as 400-600 ppm off from the actual salt reading because they use conductivity to estimate the salt level. Are you able to maintain an adequate FC level in your pool? How high is your CYA? Pentair recommends between 50-75 ppm and, IMHO, I would put it closer to the upper end of that range. Id the flow light on? Also, what is your pH? If it's continualy high (above 7.8) then that can interfere with chlorine production A SWG does not eliminate the need for proper water balance and maintenance, only from having to add chlorine to your pool manually.
    Sounds right to me
    That should have no impact on clorine generation or the readouts on the unit.
    All SWGs will shut down in a low salt condition because it will damage the cell. Your intellichlor unit will operate with salt levels up to 6000 ppm. If you are getting a low salt reading and your salt level is near the bottom end of the range (I believe the Intellichlor shuts down at 2400 ppm) then just bump up your salt. Running your salt level higher will actually help prolong cell life. If your water is balanced and your unit is producing chlorine it is working. If the low salt light is on then add salt and see if it fixed the problem. I would recommend running your salt level at around 3200-3500 ppm with a CYA of around 70 ppm. Try to keep your pH at 7.6 (if you bring it lower you will possibly need more acid to maintain the pH since it will rise faster).
    If you post a full set of test results it would be very useful.
    Thank you for that great response. You guys are so helpful.
    Here are the stats from my water test:
    FC 0.7 - I think this has been steadily dropping because the SWG isn't running.
    TC 1.5
    TA 181
    CYA 70
    PH 7.5
    TDS 3100
    Temp 84
    Here in Michigan we lower the water level in the pool a couple feet in the winter. The snow fall and rain fills it back up by the time we open in the spring, but it makes sense that every spring I should have to add salt due to draining a couple feet off in the fall, right?
    I will get those test strips for the salt and check back with you guys. Thanks again.
    TC 1.5
    TA 181
    I would lower this to around 80-90 ppm (or even lower). Several people have reported much less acid usage and much better pH stability with a lower TA when using a SWG. Once you do this you should have good pH stability if you keep your pH at aroun 7.6.
    CYA 70
    PH 7.5
    TDS 3100
    TDS is going to be the sum of your salt level and anything else dissolved in the water. I would suspect that yoursalt level is too low and you need to add salt. I suspect that your actual salt level is below the low salt cut off point of your unit. This is probably from winterizing your pool. What kind of filter do you have. If it is a sand or DE filter you also lose salt and stabilizer each time you backwash so the levels do need to be checked on a regular basis to maintain them.
    Temp 84
    I noticed you did not include a calcium test. Even if you have a vinyl pool where calcium is not an issue it is a parameter that needs to be watched with a SWG because calcium can also come from your fill water and if it is high you can get scaling on the cell, especially if you don't keep close watch on your pH.
    Exactly!
    I suspect that when you test your salt you will find it is low!
