Results 1 to 10 of 16
Thread: Any Pool Rover owners out there?
    mohawk is offline Registered+ Thread Analyst mohawk 0
    Minneapolis, MN
    Default Re: Any Pool Rover owners out there?
    Thanks for the info on the Plus. I called the 800 number listed on the instructions and they said to wash the bag because of the density of the fabric. I'm not sure if that will help with the suction of the machine, but I'll give it a try. The directions say when the Rover makes its first move across the pool it will be in a straight line. Mine never goes in a straight line. Does anyone else have a Rover that does this? Thanks for the info. Denise
    Poughquag, New York, USA.
    I only wash my filter bag occasionally. Mainly I use the method recommended by CarlD (I believe). Fill a bucket (I use a 3 gallon paint bucket from HD). Turn the filter inside out. Rinse repeatedly. Toss water and refill. Rinse and wring filter. Let air dry inside out. Works great.
    My Rover plus does go straight first, then curves, then straight/curve and so on. In one direction, it should go straight, in the other, it should curve. It sounds like you may not be putting the pin in the front (it should be moved from side to side every run or so to even out twists in the cord).
    Minneapolis, MN
    The pin is in the position the manufacturer placed it. It's set in the hole closest to the middle of the unit. It curves on almost every pass. I'll have to call the company again and see if they suggest something else. I had it clean twice today and I still have alot of dirt around the outer most edge of the pool.
    Tinley Park, Illinois, USA.
    Sorry, this is an old post but I just bought the Pool Rover Junior at Costco and was doing a search on this forum.
    Does anyone know if the Pool Rover works less efficiently in cold water? My pool temp is around 40 degrees and it's been in the pool twice (4 hours total). We still have lots of dirt in the pool. I'm wondering if maybe it's because the water is so cold and that the dirt is frozen in the water. We did take our pole and kicked up the dirt a little.
    We would heat up the pool, but our heater is on the whack. We have a repair guy coming out tomorrow. Yikes!!
    24' Above Ground Pool x 54" depth -- 14,000 Gallons (approximately) -- 1 1/2 HP Hayward DE Filter (model EC 45) -- Hayward H150 Gas Heater
  1. Calling All INTEX Pool Owners (all AG pool owners welcome of course) - Please help
    By Firstpool in forum Above-Ground Pool Construction & Repair
    Last Post: 01-24-2012, 04:50 PM
  2. Pool Rover Jr
    By Reefdiver in forum Pool Cleaning: Manual or Automatic
    Last Post: 09-09-2011, 09:13 AM
  3. Pool Rover Plus Help!
    By psciotti in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-03-2007, 10:00 PM
  4. Aquabot Pool Rover?????
    By IMherDad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-11-2006, 12:45 AM
  5. Pool Rover Plus stops often
    By DMand in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-01-2006, 08:10 PM
