Closed Thread
Results 1 to 9 of 9
Thread: pool quote
    mas985's Avatar
    Pleasanton, CA
    Default
    Seems like a good price to me but I am in Northern Cal where everything costs more.
    One comment is that I went with the Aqualogic controller and salt generator from Goldline which I paid less than $1600 for both. The Aqualogic does not require an additional controller for SWG only the cell which is about $400 more. So check some web pricing to make sure they are not overpriced. Definitely go for a SWG and controller if you can, it will make life much easier on you.
    Also, you did not mention the pipe size. I would recommend at least 2" with separate suction lines to the pad for the skimmers and main with control valves for each.
    More details in the quote would be better for your sake. Nail them down on every little detail so there are no surprises later.
    Mark
    InfinityPools is offline ** No working email address ** InfinityPools -
    Default
    don't know where your at, But that is a pretty standard price here in florida.
    Default
    I wish I was getting quotes like that, I have quotes from 73k to over 100k, with Pebbletec/PebbleSheen/diamondbrite, salt chlorinator, with spa, bbq, firepit, pool 18x36, raised bond beam wall, french drain behind wall, with another 1200ft of colored,stamped concrete. Now my prices have not even touched redoing sprinkers, or lancscaping.
    The most important thing is to get a good builder you can trust. If you save a couple of thousands dollars, but end up with a POS pool, the savings might not be worth it. Not that paying top dollar will guaranteee a great pool either.
    Default Re: pool quote
    There's a good chance the electrician is a completely seperate quote--mine was about $1200, but he did EVERYTHING perfectly, to code and EXACTLY as I wanted it, including running 40amp cable for a future heat pump, should I want one (haven't so far)
    Part of the hookup is the banding of the pool--grounding--which a licensed electrician must do.
    My town (and I believe BOCA code) also requires all pumps must have timers.
    My AG has all the features of your quote, but with solar rather than a heater. No SWG either, but it's 16x40 from 4' to 5.5' and is built in...check out the pictures in the What does your pool look like? thread.
    Because of the base it was about $21k--the base was $5k alone.
    Hanford,CA
    The one thing I see that's missing is any decking at all?
    Thanks all for your comments. It sounds like the quote I received was in the right ball park. I'm in central Va and we only have one pool builder in my area. I could go a little east to Richmond to try to find someone to give me another estimate. I'm not sure someone would want a job located an hour away from their place of business.
    The confusing parts of the quote to me were the salt water chlorinator related items. Those numbers both seemed rather high. I suppose that I need to get clarification on many things. Plumbing and electrical details. Lights. What did you folks do for lights in your pool? Does two lights sound right for a pool this size?
    There was no deck component to the proposal because we already have made arrangements with our landscaper to join the pool deck (dry laid pavers) up with the current patio. We bought enough materials when we first built the patio last year to cover the pool deck requirements.
    Chris
    Now you can purchase the aquarite at Ebay, or other online places for $699. But your price is the price I have been quoted. You could always purchase it and have someone else install it afterward. You will need to have the electrical down and and mount the box on to something. But you could save $300 to $400 or so if you pay a plumber to do it. You can also try to get a card from the plumber the pool company will use, and then hire them out to install it afterward.
    Your price on the in house controller system, is inline with my quotes, I just have not been quoted that brand. That is another thing you can install yourself and save $300 to $400 dollars or so. But again you will need to mount it, know how to wire up relays, program it up.
Closed Thread
