My cell wasn't making enough chlorine. The tech diagonised it as working intermitently. He said that the old circuit board design had caused many odd problems.
Since the circuit board was replaced the unit has been producing 5 times the amount of chlorine, while only running half the time. What a saving on electric it should be!![]()
Well my AquaPure 1400 stopped making chlorine with the code 172 181
I may need a circuit board replacement
I had the same code and problem in the spring and the pool builder replaced my circuitboard. Luckily mine was only a year old and was still under warranty. Been working wonderfully since and seems to be more efficient.
I'm curious what you folks with Aquapures run your production % at. I had mine at 30 and seemed to be keeping Cl around 3ppm with a CYA level 30-40. I bumped it up to 40 since it seemed that I was seeing too much sediment on the steps when I brushed the pool and thought it could be algae starting. All seems better now. Thanks
Pool owner - contract signed 21Aug2006; HOA approval granted; complete - existing patio demolition; excavation; rebar; embedded plumbing; gunite; plumbing; electrical; tile and coping; decking; plaster; pool fill; acid start-up; regular start-up; pool school; gas meter upgrade; additional of salt; PDA remote programming.
It's a 22K gal pool, NE Florida, no screened, heavy tree load, cell on 12 hours a day, 1400 unit, new this spring, Replaced the original Clormatic III.
