Results 1 to 9 of 9
Thread: Jandy Aquapure SWG Circuit Boad Problem
    Default Re: Jandy Aquapure SWG Circuit Boad Problem
    Since the circuit board was replaced the unit has been producing 5 times the amount of chlorine, while only running half the time. What a saving on electric it should be!
    Dec 2005
    Well my AquaPure 1400 stopped making chlorine with the code 172 181
    I may need a circuit board replacement
    Crowley, TX
    I had the same code and problem in the spring and the pool builder replaced my circuitboard. Luckily mine was only a year old and was still under warranty. Been working wonderfully since and seems to be more efficient.
    I'm curious what you folks with Aquapures run your production % at. I had mine at 30 and seemed to be keeping Cl around 3ppm with a CYA level 30-40. I bumped it up to 40 since it seemed that I was seeing too much sediment on the steps when I brushed the pool and thought it could be algae starting. All seems better now. Thanks
    Sugar Land, Texas
    Quote Originally Posted by keastman View Post
    I believe that, for this information to be useful, it needs to be accompanied by the pool volume and whether the user is running a 700 or 1400 system.
    Pool owner - contract signed 21Aug2006; HOA approval granted; complete - existing patio demolition; excavation; rebar; embedded plumbing; gunite; plumbing; electrical; tile and coping; decking; plaster; pool fill; acid start-up; regular start-up; pool school; gas meter upgrade; additional of salt; PDA remote programming.
    It's a 22K gal pool, NE Florida, no screened, heavy tree load, cell on 12 hours a day, 1400 unit, new this spring, Replaced the original Clormatic III.
