Results 1 to 9 of 9
Thread: testing during conversion
    KatieD is offline ** No working email address ** KatieD 0
    Jul 2006
    Default testing during conversion
    I've ordered a test kit from Ben, but it won't be here until next week. In the meantime, I've purchased liquid chlorine from my pool supply co and would like to start adding it tonight.
    Can anyone recommend a test kit I could purchase in the meantime to check my chlorine levels during conversion?
    Default Re: testing during conversion
    If you have an oto test that measures up to 5, you can use one part pool water to one part steam distilled water, mix well, test a sample from that, read your results, and multiply by 2. Or if you need to go higher, mix it 1:2 and multiply by 3. You lose a little accuracy with each dilution, but it'lll give you a ballpark until Ben's kit comes in.
    Jul 2006
    Hi!
    Thanks for the response aylad, but I have no idea what an oto test is, and I'm sure I don't have one. Is that something I should try to purchase right now, and if so, where would I find one?
    Jul 2006
    You can purchase at Walmart, I found mine at K-mart. Both go up to 5, so to get higher levels you will have to use the method above.
    Northern Kentucky
    You can pick one up at wal-mart. They usually have the chlorine test (uses OTO reagent) and pH test. very inexpensive.
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
    Jul 2006
    Thanks very much Grace and clay!
    I'm off to Walmart!
    Jul 2006
    Yay! I'm so excited, I finally saw my first "baquagoo"! 7 gallons of 12% bleach...and counting!
    This should be an interesting weekend!
    Northern Kentucky
    You know, this is a weird forum... we get excited about the grossest things!
    baquagoo, algea and scum, oh my!!
    ~Grace
    Jul 2006
    Quote Originally Posted by GraceByDesign
    I know, it's funny isn't it? I'm all excited because my pool is looking horrible!!
    But only because this time it's by design instead of the usual "by Baquacil"!
  1. 1 year after conversion
    By jeffmull in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 09-03-2012, 09:28 PM
  2. conversion
    By chalk2024 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-20-2006, 11:47 PM
  3. chemicals that aid conversion?
    By KatieD in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-03-2006, 05:49 PM
  4. Almost 2 weeks after the conversion
    By surfacefeeder in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-03-2006, 01:20 PM
  5. conversion
    By bwalsh1 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-27-2006, 02:33 PM
