Results 1 to 10 of 14
Thread: Weeened off pool products.
    Jul 2006
    Default Re: Weeened off pool products.
    How do I know how much bleach to use to get rid of .2 CC?? based on a 15,000 gal pool.
    Scottsdale, Arizona
    Take a look at your SWG specs. Salt - 2900 ppm may be a little on the low side. The system will generate more chlorine at a lower setting with higher salt levels.
    Jul 2006
    I have an Pentair IG20, the light indicates that it is still in the good salt range, I think its 2500-4000, I guess I could bump it up a little.
