Thread: Muriatic Acid
    duraleigh Guest
    Default Re: Muriatic Acid
    Not unless they dosed the pool with a couple of barrels!!!
    I have always felt very comfortable entering the pool after as little as 30 minutes. The dilution ratio with a reasonable dosage is pretty astronomical...say 50,000 to 1....and, provided the pump is running, it's distributed quite quickly.
    Sanford, FL
    Totally figured it was a bunch of hog-wash - but better safe than sorry. I am so excited - our pool will be done by next weekend - so I am making sure I understand everything.
    Thanks!
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    CToon is offline Registered+ Thread Analyst CToon 0
    Elkins Park,Pa
    Muriatic acid might actually be the safest once it's on the pool. Like duraleigh said , since the amount is small and it dilutes quickly , not much to worry about swimming
