Re: Frustrated Baquacil Customer
Just a little progress update for those who are interested in converting, so they know what to expect. Last night I started and when I put in my chlorine to 15ppm, my pool was a dark brownish green murky color. This AM, I tested and redosed, added 2.5 gallons and my pool is now a cloudy pea green soup color.
This afternoon I'll check again and redose and then again this evening, will keep you informed of my interesting colors.
Jaybird,
The more often you test and redose to 15 PPM the quicker your conversion will be. I did mine 3x a day, and I was finished in about 4 days. If you can test every 3 hours or so over the weekend and add bleach it will expedite it greatly. Good luck and keep us posted?
Thank you, I wish I could check more often this morning, but unfortunately I had to come into work for a bit and catch up on a few things, however when I go home today, I will definately take your advice, as I'd like for this to go as quick as possible.
You guys are so great here and very helpful. After my horrible pool store experience this is so refreshing.
Make sure that you're frequently checking your filter because the Baquagunk will build up on it, causing your pressure to rise.
Thanks for checking on that!!
I am checking and backwashing my filter everytime I test, seems to be running well.
I've added 4 more gallons since I last posted, at two seperate test times. Pool still extremely pea soup and cloudy, however I couldn't see the bottom before and now I can almost make out the bottom of the pool. Hopefully that's progress in the right direction. Just trying to keep my hubby at bay.
Keep hammering away with bleach to 15 PPM as often as you can. Once it starts breaking and you can see the bottom, you are heading downhill from there. You will absolutely be amazed when you are done and see how clear your water can be. Good luck!
Redosed to 15ppm this AM, I'm going to have to make another bleach run.
I was a might bit discouraged this AM as I didn't see any improvement from yesterday evening and I'm still pea green cloudy colored, I'm home all day and plan on check approximately every 3 hours and trying to keep the levels up.
How many days is typical for this process??
