Results 1 to 10 of 27
Thread: Frustrated Baquacil Customer
    Default Re: Frustrated Baquacil Customer
    Redosed to 15ppm this AM, I'm going to have to make another bleach run.
    I was a might bit discouraged this AM as I didn't see any improvement from yesterday evening and I'm still pea green cloudy colored, I'm home all day and plan on check approximately every 3 hours and trying to keep the levels up.
    How many days is typical for this process??
    VOLDADDY is offline Lifetime Member Weir Watcher VOLDADDY 1 star
    There is no typical answer here, it depends on several things, like amount of Baquacil you are fighting, # of gallons in your pool, how many times you are dosing to 15 PPM, etc...Patience is a virtue in the conversion. I have an 18 x 36 IG pool with around 21k gallons, I had a high Baquacil level, and my conversion took about 4-5 days. I dosed 3x a day, once early morning, once when I got home from work, and once before bedtime. Hang in there, it will all be worth it in the end!
    Thanks VolDaddy for the info.
    I've been much more diligent today and I'm beginning to have hope. Pool looks kind of gatorade green and I can see the bottom step of the ladder and can almost make out the bottom of the pool.
    The only bad thing is I live in Texas and we are in the heat of the day, just checked and my chlorine was down to 3ppm after only 3 hours, so dosing back up again.
    My garbage man is going to freak when he sees all the bleach bottles.
    That's how quickly the bleach is consumed, by both Baquacil and sunlight. Your bleach eats away at the Baquacil best when the sun is down, so if I were you i would test at least 2 more times tonight and dose to 15, and then right before bedtime. Then as soon as you get up early Am test and dose again.
    I posted my conversion pics here a while back. Look on the first page for it and you can see how my pool looked, and gauge where you are at. You will have a brand new sparkling pool to enjoy and show off to family and friends next weekend!
    Well, I have heart, woke this AM and put more chlorine (bleach) in, I was down to 3 ppm again. added 10 Liters of bleach, back up to 15 ppm.
    The good news is that the pool looks less like bright green gatorade and more like a pale green color, I can see the bottom a little better and seems it's starting to clear a bit more. So, I must be heading in the right direction.
    I brushed the pool yesterday, side and bottom, I'm thinking I should have vacuumed to waste as I got all kinds of scummy stuff floating around, some was white and some was orange, all of it kind of slimey looking.
    Should I just brush or vacuum, should I vacuum to waste or wait for the whole process to be finished before I do that part??
    Again, thanks to you guys for all your help so far, I'm really excited at having a clear pool and can't wait to get back to swimming. I do laps 3 times a week, so I'm really missing my exercise.
    stma is offline Registered+ Thread Analyst stma 0
    Poconos, PA
    Hi "Jay":
    When I did the conversation 2 years ago, I brushed, vacuumed to waste and added additional water when it was needed...I did this every day of the conversion
    Your water "color chart" is/was identical to my pool water during the conversion..so you're definitely on track....
    One of the past posters had a very good point though, and thats to wait till the sun goes down to blast up to 15ppm's..then repeat the same in the AM hours...it sounds as though you're losing a ton of ppm's in the Texas daylight...
    Total conversion for me was 7 days....(crystal in 5 and a few extra "insurance" days of high CL levels to complete the process)
    When everything is said and done with the conversion, PLEASE make sure to change out your sand (I think you said you have a sand filter)...not doing so will bring you back to square one again..
    Let us know how you're doing ?? Haven't heard from you in a few days...
    Thanks for check in, I'm doing great, pool is clearer than it has ever been, we changed out the sand last night, added more bleach and then stabilizer to 30ppm.
    I am so happy and excited, this is what a swimming pool is supposed to look like!!
    I wasn't sure about the recommended level for stabilizer and I didn't want to over stabilize. What is the recommened level.
    Thanks!!!
