Thread: Okay to add acid and chlorine at same time?
    Orlando, Florida, USA.
    Default Okay to add acid and chlorine at same time?
    My gunite pool is about 3 weeks old now. I have been keeping the water balanced with Ben's test kit.
    Today's readings are"
    FC 1 or 2
    PH 7.8
    ALK 90
    CA 200
    CYA 40
    temp 80
    I added 1/4 gallon (32 oz) of Muratic Acid
    I would like to add a 1/2 gallon of 5.25% bleach.
    Can I add both at the same time?
    duraleigh Guest
    Default
    Hi,
    Short answer...Yes.....assuming you don't mean simultaneously.
    I will frequently add Cl to my skimmer and then follow shortly by adding muriatic to the return jet stream. You might even be able to add muriatic to the skimmer but that just doesn't seem like a good idea to me. Into the return stream allows for instant dilution and rapid dispersion.
    Of course, never mix them....never mix the muriatic with anything but water.
    So if you do them as sequential operations, no problems.
    DaveS.
    PS....good numbers!! (little more Cl, please )
  1. Cyanuric Acid Chlorine Conditioner
    By JohnASmith in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-14-2013, 09:21 PM
  2. Cyanuric Acid Chlorine Conditioner
    By JohnASmith in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-09-2013, 09:36 PM
  3. Muratic Acid to swim time?
    By JJParrish in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-29-2007, 11:07 PM
