Bleach Conversion Crisis Continues.....
More detail to add to the ongoing conversion crisis!!
I put 4 gallons bleach in Monday, 7/31/06 (Ultra from Wal-Mart) in addition to the stabilizer and muriatic acid the pool store recommended. I put 4 gallons Chlorox in Wednesday. I also put in 4 gallons Ultra and 1 gallon Chlorox in Thursday and swept and vacuumed. Is this too much bleach??? My pool is 40,000 gallons. the chlox I got from Sam's didn't say anything on the box about a whitening ingredient, so I don't know if it was in there.
We also have a "Frog mineral reservoir" we use. This is all I have put in there this week. The water does look somewhat better today, but is still cloudy, and when I sweep clouds of white precipitate billow up. I am following advice of aylad (thanks!) and will vacuum this evening and am running the pump. Also the end of our filling hose doesn't look too good. I think I may have bleached it out. I hope my liner is okay. It looks okay. I long for a clear sparkling pool. The weather has been in the 95-105 degree range and maybe some of the precipitate is dead algae??? The only other time we have had a whitish cast to the pool water was when we shocked it this spring with shock that had about 40% of inert ingredients.We drained out probably 20,000 gallons to get rid of that .My husband put in a lot of that week before last before I decided to try the bleach so some of the precipate may be residual from the shock. Should I shock some more tonight? Thanks so much for your help. kecsmom
