We might be rushing to judgement just a little to start treating metals without any other test resultsClearing pond water requires maintaining a chlorine level of around 12 + 'til the water clears. That requires testing and adding a minimum of twice daily for the duration.All of the chemical readings are good with the exception of the chlorine of course.
I'm not sure metals are common in pond water but I know what is.....organics........lots of 'em. Chlorine, and lots of it, will probably clear your pool. If you didn't add chlorine in the quantity and consistency above, I would do that first.
For what it's worth, I have filled my pool twice with pond water and cleared it with bleach......nothing else.
