Results 1 to 10 of 15
Thread: How would you rate this proposal
    y0manda is offline Registered+ Thread Analyst y0manda 0
    Default Re: How would you rate this proposal
    I had my plumber install one for me.
    Have them run it where your pool equiptment is and then back to where you want the filler to be. That way you are able to turn it off when you need. i.e. checking for leaks. My pool sometimes looses 1/3" a day from evaperation and splashing. It would be about 3-5 and the water would be below the skimmer and (if I didnt have a 15minute flow monitor on my pump) It could ruin your pump. It's another feature that goes hand in hand with a SWCG - low pool maintance.
    another low maintance feature would have to be the overflow drain.
    http://y0manda.serveftp.net:81/album...0015.sized.jpg
    the white flattened thing that sits flush on the bond beam (left of the sponge) just hook it upto your drains, the plumber left this for me when he finished and I just cut a into my bond beam and used polyurethane to adhear it. Great when it rains and don't want your pool water overflowing.
  1. Flow rate sensor?
    By henryb in forum Pool Electronics
    Last Post: 08-31-2013, 03:51 PM
  2. Getting a better turn over rate
    By Ecozadd in forum Commercial Pool Users, Managers & Workers
    Last Post: 07-30-2012, 05:45 PM
  3. Pump Rate
    By iwannapool in forum Pool Equipment & Operations
    Last Post: 06-22-2007, 07:38 PM
  4. PVC Maximum Flow Rate?
    By catnip in forum Pool Equipment & Operations
    Last Post: 03-14-2007, 01:15 PM
  5. Design flow rate vs maximum flow rate...
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-27-2006, 07:50 AM
