Re: Best way to lower calcium?
Are your other numbers pre or post pH adjustment? If they are pre-adjustment, your water was in a slightly-scaling condition. If they are post-adjustment, your water is balanced. Basically the deal is, that if you let your pH go high, you are going to get in a scale-forming condition. That's what's causing what you are seeing. If you keep your pH around 7.4, you shouldn't have a problem.
FWIW, your Ca is not high. I qualify high Ca as 500+
. You're not there. IG plaster pools generally run 400 or so ppm as a rule.
Michael
Michael,
I've seen some differing info about this. Acceptable ranges listed as 200 to 1000 ppm, for example.
What would you say is the acceptable range and the ideal?
Thanks,
Lenny
For an in-ground, plaster pools, the generally accepted range is 200 - 400. As you get higher in Ca content in the water, your chances of being in a scaling condition increase. I'm about to start a ruckus with a Ca thread, so stay tuned.
Michael
