Results 1 to 9 of 9
Thread: Average ppm loss on BBB?
    Default Average ppm loss on BBB?
    Is there an average normal ppm of chlorine loss? My pool lost about 6 ppm today. Is that normal? I had shocked it up to 20 ppm, and it took a couple days to come down to 10. This morning it was about 9, and it was only at 3 when I tested this evening.
    Intex Easy Set 18 x 4-foot pool; second year.
    Heartland
    Default Re: Average ppm loss on BBB?
    Here is a post that may shed some light:
    http://www.poolforum.com/pf2/showthr...highlight=lose
    When I first switched to BBB I was burning 5-6 ppm. I switched from Prestine Blue so I had no stabilizer in the pool. Now, three weeks later I'm burning about 2-3 ppm. I went from using a 1.42 gallon jug of clorox everyday to using 1/3 of a jug everyday.
    Mandeville, LA, USA.
    Quote Originally Posted by Snowymoon
    Chlorine loss is a function of several variables including CYA level, sunlight exposure, and how much work there is for the chlorine to do.
    That depends. What is your CYA level?
    Why did you shock (algae, heavy swimmer load?)? If there was much for the chlorine to do (e.g. sanitizing and oxidizing) much of it will have been consumed doing what it's supposed to do.
    6 ppm per day is pretty high for "normal" conditions. You probably have no or low levels of CYA and/or your chlorine is battling something. Post a full set of test results and people here will help you figure this out.
    Heartland
    Here is a thread that I started that was talking about my CYA and chlorine loss. My CYA wasn't showing up in my tests:
    http://www.poolforum.com/pf2/showthread.php?t=4372
    I still don't agree with my CYA reading that I get, but my chlorine loss is stable at 2-3 ppm everyday and that is way down from my earlier readings when we first switched. So, I think the stabilzer is in there.
    My CYA level is at 70. I don't think that is the issue. It was in the mid 80s and sunny all day yesterday, but there were only 2 of us in the pool. However, we have had a lot of thistle seed tufts that are blowing into the pool from the lot next to ours. Pool was uncovered in the sun all day yesterday.
    My guess then is that your chlorine is fighting something.
    That probably accounts for at least 2 ppm of loss.
    However, we have had a lot of thistle seed tufts that are blowing into the pool from the lot next to ours...
    That may account for a bit more loss.
    I'm guessing here, but I think you have some additional chlorine loss that's not accounted for by the known consumers. I recommend you bring your chlorine to shock level (per Ben's "Best Guess" table) and keep it there until the level holds overnight.
    A full set of numbers would still be helpful.
    mas985's Avatar
    Pleasanton, CA
    I think Chemgeek showed that chlorine loss as a percentage of the residual ppm increase with higher residuals. If you have a residual of 9 ppm, then it may not be unreasonable to lose 6 ppm.
    I have a SWG and I know that I am putting in 2 ppm per day but my residual is also 2 ppm so technically, I am losing 100% of what I put in every day.
    Mark
  1. Average daily chlorine loss and CYA
    By jwhouse in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-04-2012, 07:02 PM
  2. Aquarite instant or average?
    By dannyboy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-23-2007, 06:41 PM
  3. Average life expectancy of pump
    By bboehm in forum Pool Equipment & Operations
    Last Post: 04-21-2007, 12:07 PM
  4. Average Maintenance Costs?
    By s6skuzy in forum Pool Equipment & Operations
    Last Post: 07-10-2006, 10:55 AM
  5. Does CYA 'degrade' at any sort of average rate?
    By aquarium in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-17-2006, 10:33 AM
