Thread: Shotgun pellets or BBs in bottom of pool
    Winston Salem, NC
    Default Shotgun pellets or BBs in bottom of pool
    Today while cleaning our pool, I noticed 5 or 6 dark reddish brown spots on the bottom of our vinyl liner pool that weren't there a couple of weeks ago. I tried several times to vaccuum them up, but it finally dawned on me that it was some type of stain on the vinyl. When vaccuuming the last spot, I noticed something kind of roll out of the spot. So, I got into the pool and fished the item out. It appears to either be a shotgun pellet or BB, perhaps a small ballbearing but I can't imagine from what.
    Does anyone know what may remove the reddish brown stains that the pellets have left on the vinyl liner?
    duraleigh Guest
    Default Re: Shotgun pellets or BBs in bottom of pool
    Lots of folks on the forum report Vitamin C tablets (ascorbic acid) as effective against rust stains. Apply the crushed tablets directly onto the stain.
    mbar's Avatar
    Ashland, PA
    Sometimes ascorbic acid does not remove rust stains. Try a Mr. Clean magic eraser - it should do the trick.
    Northeast PA
  1. Can't get bottom flat, can pool bottom be slightly concave/bowl shaped?
    By SkierDude in forum Intex-type Pool Setup & Operations
    Last Post: 06-30-2013, 12:13 PM
  2. Diamond Crystal 40 Lbs. Iron Reduction Salt Pellets
    By Jasheon in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-22-2011, 11:36 AM
  3. Help,not sure what this is on bottom of pool
    By sisie5 in forum Dealing with Algae & Slime
    Last Post: 09-02-2006, 01:42 PM
  4. what is this in the bottom of my pool?
    By martinsvillemark in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-05-2006, 11:29 PM
  5. Pool bottom
    By crosso in forum In-Ground Pool Construction and Repair
    Last Post: 04-03-2006, 12:40 PM
