Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Combined Chlorine Test
FAQ
register
Results 1 to 10 of 10
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
08-06-2006
10:21 PM
#6
Jakebear
View Profile
View Forum Posts
Registered+
Thread Analyst
Jul 2006
Pennsylvania
Re: Combined Chlorine Test
See edit --- I had a brain fart --- it is standard Clorox Ultra. Thanks for the catch!!
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
Cloudy water Help!!
Why test CYA?
Strange test results -- very high combined chlorine (CC)
By Themadczar in forum Dealing with Alkalinity and Calcium
56
Last Post:
08-05-2013,
11:27 PM
new test kit - checking combined chlorine?
By samtex in forum Testing and Adjusting Pool Water Chemistry
5
Last Post:
06-26-2013,
01:16 AM
1 ppm combined chlorine
By fhorta in forum Dealing with Algae & Slime
1
Last Post:
05-31-2013,
11:40 AM
Need help getting rid of 7 ppm combined chlorine
By mtroyalm2 in forum Pool Chemicals & Pool Water Problems
4
Last Post:
05-10-2012,
10:04 PM
Initial test results...green ring, combined chlorine...HELP!!!
By Sheri in forum Testing and Adjusting Pool Water Chemistry
7
Last Post:
07-16-2010,
12:51 PM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
